Hello,Just for your information, I was able to pack together a quick and dirty legend site. Unfortunately, I can't make it accessible for you to view, but the code should work if you are using a 10 SP1 or higher map service. It is basically a copy of the regular sample, but it loads a local dynamic map service at map load time. You would change the piece in bold to point to your local map service or any other 10.01 or higher service.<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Map with legend</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
<style>
html, body { height: 98%; width: 98%; margin: 0; padding: 5px; }
#rightPane{
width:20%;
#legendPane{
border: solid #97DCF2 1px;
</style>
<script type="text/javascript"> var djConfig = { parseOnLoad: true };</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.layout.AccordionContainer");
dojo.require("esri.map");
dojo.require("esri.dijit.Legend");
dojo.require("esri.layers.FeatureLayer");
var map;
function init() {
map = new esri.Map("map");
//Add the terrain service to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
var basemap = new esri.layers.ArcGISDynamicMapServiceLayer("http://gisvirt02/ArcGIS/rest/services/Voting/Voting/MapServer");
map.addLayer(basemap);
//add the legend
dojo.connect(map, 'onLoad', function () {
var legendDijit = new esri.dijit.Legend({map: map}, "legendDiv");
legendDijit.startup();
dojo.connect(map, 'onLoad', function (theMap) {
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
<div id="rightPane" dojotype="dijit.layout.ContentPane" region="right">
<div dojoType="dijit.layout.AccordionContainer">
<div dojoType="dijit.layout.ContentPane" id="legendPane" title="Legend" selected="true" >
<div id="legendDiv"></div>
</div>
<div dojoType="dijit.layout.ContentPane" title="Pane 2" >
This pane could contain tools or additional content
</div>
</div>
</div>
<div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
</div>
</div>
</body>
</html>
