AnsweredAssumed Answered
Append not working
Question asked by recurvata on Mar 30, 2012
Latest reply on Mar 30, 2012 by recurvata
Any ideas why Append is throwing the error below? There are three parcels selected, that I'm trying to append to the Cases feature class. As far as I can tell, there's absolutely nothing that's using Cases. No one else has access to this geodb, so it's not a case of another user, and I'm not doing anything else with it. Using Append from the toolbox works fine. Thanks.
Code:
import arcpy from arcpy import env  env.workspace = r"\\TestServer\TestCases_Geodatabase.gdb"  #------------------------------------------------------------------------------- # Append selected parcels to Cases #  def AppendParcelsToCases():     input = "Parcel"     target = "Cases"     schemaType = "NO_TEST"      try:         arcpy.Append_management(input, target, schemaType)     except Exception as e:         arcpy.AddError("Error creating case feature! \n" + e.message)
Error:
Executing: CreateCase Start Time: Fri Mar 30 11:01:12 2012 Running script CreateCase... Error creating case feature!  ERROR 999999: Error executing function. Cannot acquire a lock. Cannot acquire a lock. [The table Cases is being written by another process.] Cannot acquire a lock. [The table Cases is being written by another process.] Failed to execute (Append).  Completed script CreateCase... Failed to execute (CreateCase). Failed at Fri Mar 30 11:01:16 2012 (Elapsed Time: 4.00 seconds)
Outcomes
