Tool Cost Distance - Error 010005 and 010067
1172
03-29-2012 11:49 AM
MatthiasWoerner
New Contributor III
Dear all,
I use ArcGIS 10.0 and faced this problem when executing the tool Cost Distance: I get back the Error 010005 and 010067.
Already posted comments on Error 010005 suggest that there is not enough RAM available. I don't consider this to be the problem on my computer. As well the used datasets are rather small. I tried running the tool with ArcCatalog closed and as well all other software closed except for ArcMap - but with the same error message.
Did anybody face the same problem or has a good idea how to solve this?
Many thanks in advance,
Matt
TarunJaiswal
Greetings!
Please try setting a scratch workspace and run the tool. Also, you may want to clean temp directory and to consider repathing it closer to root such as c:\temp.
Hope this helps.
Thank you.
MatthiasWoerner
New Contributor III
Greetings!
Hope this helps.
Thank you.
Dear Tarun,
Thanks for your suggestions. I moved the geodatabase to a path close to directory c:\temp and ran the tool with an adequate scratch workspace. But with the same result. In fact my directory c:\temp is almost empty so this should not be the problem.
Still thankful for any suggestions,
Matt
DanPatterson_Retired
try running it with an ESRI grid in a folder and not a geodatabase
MatthiasWoerner
New Contributor III
Dear Tarun and Dan,
Thanks a lot for your suggestions. I followed these and some other ideas in order to solve the problem. In the end it was a little stupid mistake I made. I didn't enter the Extent values in the Geoprocessing Environments. After catching up this the tool ran without objection.
Thanks anyway,
Matt
