smellanbyesriuk-esridist
wms layer format in options not used in request
Discussion created by smellanbyesriuk-esridist Employee on Mar 21, 2012
Should the options parameter image format work as I have below? When you set the value for image format by wmsLayer.setImageFormat('svg') it works, but via options.format it's ignored?
Any thoughts? I'm after a gif :-) all I can get is svg or png? Does setting a background colour still require you use a custom wms layer like http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/layers_custom_wms.html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
   <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Map with WMS</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.7/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body { height: 98%; width: 98%; margin: 0; padding: 5px; }
    </style>
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.7"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.layout.AccordionContainer");
      dojo.require("esri.map");
      dojo.require("esri.layers.wms");
      var map;
      function init() {
        //esri.config.defaults.io.proxyUrl = "http://localhost:8080/sampleapp/proxy.jsp";//"/arcgisserver/apis/javascript/proxy/proxy.ashx";
        var initExtent = new esri.geometry.Extent({"xmin":-19000410,"ymin":860986,"xmax":606604,"ymax":8570731,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map",{extent:initExtent});
        var layer2 = new esri.layers.WMSLayerInfo({name:"2", title:"test"});
        var resourceInfo2 = {
          extent: initExtent,
          layerInfos: [layer2]
        var options = { resourceInfo: resourceInfo2, visibleLayers: ['2'], format: 'gif' };
        var wmsLayer = new esri.layers.WMSLayer("http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer",options);
        //works here but not above? and only for svg, not gif
        //wmsLayer.setImageFormat("gif");
        console.debug(wmsLayer.imageFormat);
        map.addLayer(wmsLayer);
        dojo.connect(map, 'onLoad', function(theMap) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
      <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
      </div>
    </div>
  </body>
</html>
Outcomes
