First post on this forum, and I am new to the ArcGIS products, so keep that in mind with this post...
I created a set of lines within a feature class using network analyst. To keep this post short, the way in which I did this, the analysis created duplicate lines. I'd like to delete the duplicates, which have the same line lengths. When running Delete Identical (with SP4 installed), not all duplicates are deleted. Does any user or admin of the forum have any info on how to make this work? I do have a work-around using excel, but it will add significant amount of time to what I'm doing.
Thanks for any replies in advance.
Cheers,
Bob Smith
Cheers,
Bob Smith
I don't think it is an issue of SP 4, I just ran the tool on SP4 and all identical lines are deleted. What field are you using to compare identical? Are the values compleatly identical that are not being deleted. You can use the shape field to delete identical and include a search tollerance.
Delete Identical (Data Management)
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000053000000
