Thank you Server Team for the great examples.
# Demonstrates how to start a service by starting the geometry service
# This service is included with every ArcGIS Server and is stopped by default
# For Http calls
import httplib, urllib, json
# For system tools
import sys
# For reading passwords without echoing
import getpass
# Defines the entry point into the script
def main(argv=None):
# Print some info
print
print "This tool is a sample script that starts the Geometry service on a Server."
print
# Ask for admin/publisher user name and password
username = raw_input("Enter user name: ")
password = getpass.getpass("Enter password: ")
# Ask for server name
serverName = raw_input("Enter server name: ")
serverPort = 6080
# Get a token
token = getToken(username, password, serverName, serverPort)
if token == "":
print "Could not generate a token with the username and password provided."
return
# Construct URL to start a service - as an example the Geometry service
serviceStartURL = "/arcgis/admin/services/Geometry.GeometryServer/start"
# This request only needs the token and the response formatting parameter
params = urllib.urlencode({'token': token, 'f': 'json'})
headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
# Connect to URL and post parameters
httpConn = httplib.HTTPConnection(serverName, serverPort)
httpConn.request("POST", serviceStartURL, params, headers)
# Read response
response = httpConn.getresponse()
if (response.status != 200):
httpConn.close()
print "Error while attempting to start the service."
return
else:
data = response.read()
httpConn.close()
# Check that data returned is not an error object
if not assertJsonSuccess(data):
print "Error returned by operation. " + data
else:
print "Operation completed successfully!"
return
# A function to generate a token given username, password and the adminURL.
def getToken(username, password, serverName, serverPort):
# Token URL is typically http://server[:port]/arcgis/admin/generateToken
tokenURL = "/arcgis/admin/generateToken"
# URL-encode the token parameters
params = urllib.urlencode({'username': username, 'password': password, 'client': 'requestip', 'f': 'json'})
httpConn.request("POST", tokenURL, params, headers)
# Read response
httpConn.close()
print "Error while fetching tokens from admin URL. Please check the URL and try again."
return
else:
httpConn.close()
return
# Extract the token from it
token = json.loads(data)
return token["token"]
# A function that checks that the input JSON object
# is not an error object.
def assertJsonSuccess(data):
obj = json.loads(data)
if 'status' in obj and obj['status'] == "error":
print "Error: JSON object returns an error. " + str(obj)
return False
else:
return True
# Script start
if __name__ == "__main__":
sys.exit(main(sys.argv[1:]))
