daniel1984
Proxy specific map services instead of all map services
Discussion created by daniel1984 on Mar 19, 2012
Latest reply on Mar 21, 2012 by ciava.at
For my map viewer, I am using a proxy page with token authentication. When I set "alwaysUseProxy=true", every time i add a map service as a new layer to my base map, the proxy page is called. Is there a way to proxy specific map services instead of all of them?
Here is a scenario: if I want my base map to use a map service from my ArcGIS server, then my map viewer should call the proxy page to retrieve a token so it can display the base map. Then I want to add a layer using a map service from ArcGISOnline. During this event, I do not want the proxy page to get called. After that, I want to add another layer using a map service from my ArcGIS server. This means that the proxy should get called again to retrieve another token.
Please let me know if this is possible.
Outcomes
