Using custom code in ArcMap: Exporting Crystal Report XI into PDF Freeze - Vb.Net2005
526
03-18-2012 08:51 PM
dgesridgesri
Occasional Contributor II
Greetings
I have an application developed with Vb.Net 2005 and Crystal report XI used to preview many statistical reports.
I always preview any report successfully, but when exporting any report that contains a Chart into pdf using the built-in export functionality in the report viewer control, the application freezes forever.
While when exporting any report that does not contain any chart into pdf, it exported successfully and with no errors.
So, I need to know if there is a some way / Solution / workaround that I could use to fix my issue and let my export process continue successfully.
please can I have a little help over here...
Please advise...
Thanks in advance....
PhilBlondin
New Contributor III
using a free pdf printer engine like primo pdf and then print it to that from the control and see if it still hangs.
