using System; using ESRI.ArcGIS.Carto; using ESRI.ArcGIS.Geodatabase; using ESRI.ArcGIS.Location; using ESRI.ArcGIS.Geometry; namespace ZoomToEvent { class Program { static void Main(string[] args) { try { //Get license. ESRI.ArcGIS.RuntimeManager.BindLicense(ESRI.ArcGIS.ProductCode.EngineOrDesktop); //Open a map document with event tables and displayed event layers. MapDocumentClass pMapDocumentClass = new MapDocumentClass(); string path = "C:\\temp\\Test.mxd"; pMapDocumentClass.Open(path, string.Empty); IMapDocument pMapDocument = pMapDocumentClass; IMap pMap = pMapDocument.ActiveView.FocusMap; ILayer pLayer; IFeatureLayer2 pFl; IFeatureClass pFc; IDataLayer2 pDLayer; IRouteEventSourceName pESN; IDatasetName pDSN; IFeature pF; IEnvelope pEnv; IGeometry pGeo; IFeatureCursor pFcursor; Console.WriteLine("Checking " + path); Console.WriteLine(); for (int i = 0; i < pMap.LayerCount; i++)//Loop TOC for displayed route events { if (pMap.get_Layer(i) is IFeatureLayer) { pLayer = pMap.get_Layer(i); pFl = (IFeatureLayer2)(pLayer); pFc = pFl.FeatureClass; if (pFc is IRouteEventSource) { //Identify source table of event data. pDLayer = (IDataLayer2)pLayer; pESN = (IRouteEventSourceName)pDLayer.DataSourceName; pDSN = (IDatasetName)pESN.EventTableName; Console.WriteLine("Found displayed event layer."); Console.WriteLine(" Layer Name: " + pLayer.Name); Console.WriteLine(" Source Table: " + pDSN.Name); //Print first record's envelope extent - use for display extent... pFcursor = pFc.Search(null, false); pF = pFcursor.NextFeature(); pGeo = pF.Shape; pEnv = pGeo.Envelope; Console.WriteLine(" First record's extent: "); Console.WriteLine(" " +pEnv.XMax + ", " + pEnv.YMax + ", " + pEnv.XMin + ", " + pEnv.YMin); Console.WriteLine(); } } } } catch (Exception e) { Console.WriteLine("{0} Exception caught.", e); } Console.ReadLine(); } } }
private void timer1_Tick(object sender, EventArgs e)
ESRI.ArcGIS.Carto.IActiveView pAV;
ESRI.ArcGIS.Carto.IMap pMap;
ESRI.ArcGIS.Geodatabase.IEnumFeature pEnumF;
ESRI.ArcGIS.Geodatabase.IFeature pF;
IDocument doc2 = m_application.Document;
IMxDocument mxdoc2 = (IMxDocument)doc2;
IMap map2= mxdoc2.FocusMap;
ITable table = (ITable)(map2.get_Layer(0) as IFeatureSelection);
QueryFilter searchFilter;
double minX, minY, maxX, maxY;
minX = 45600048.45;
maxX = 0;
minY = 80000054.56;
maxY = 0;
foreach (object cekirani in checkedListBox2.CheckedItems)
int d = cekirani.ToString().IndexOf(',');
//MessageBox.Show(cekirani.ToString().Remove(d));
searchFilter = new QueryFilter();
searchFilter.WhereClause = "Ime='"+cekirani.ToString().Remove(d)+"'";
ICursor kursor=(ICursor)table.Search(searchFilter,true);
IRow row = kursor.NextRow();
int ime=row.Fields.FindField("Ime");
int alias = row.Fields.FindField("Alias");
int iks = row.Fields.FindField("X");
int ipsilon = row.Fields.FindField("Y");
while(row!=null)
if (Convert.ToDouble(row.get_Value(iks))<minX)
minX = Convert.ToDouble(row.get_Value(iks));
if (Convert.ToDouble(row.get_Value(iks))>maxX)
maxX = Convert.ToDouble(row.get_Value(iks));
if (Convert.ToDouble(row.get_Value(ipsilon))<minY)
minY = Convert.ToDouble(row.get_Value(ipsilon));
if (Convert.ToDouble(row.get_Value(ipsilon))>maxY)
maxY = Convert.ToDouble(row.get_Value(ipsilon));
pMap = (IMap)map2;
pEnumF = (IEnumFeature)pMap.FeatureSelection;
pF = pEnumF.Next();
ESRI.ArcGIS.Geometry.IEnvelope pEnv;
pEnv = new EnvelopeClass();
pEnv.SetEmpty();
pEnv.XMin = minX;
pEnv.XMax = maxX;
pEnv.YMin = minY;
pEnv.YMax = maxY;
pEnv.Expand(2.5,2.5,true);
pAV = mxdoc2.ActiveView;
pAV.Extent = pEnv;
pAV.Refresh();
private void listBox1_SelectedIndexChanged(object sender, EventArgs e) { try { IMap pMap = pMxDoc.FocusMap; //Clear all selected features. pMap.FeatureSelection.Clear(); IFeatureLayer pFl = (IFeatureLayer)pMap.get_Layer(0); IFeatureClass pFc = pFl.FeatureClass; IQueryFilter pQf = new QueryFilterClass(); pQf.WhereClause = pFc.OIDFieldName + " = " + listBox1.SelectedItem; IFeatureCursor pFcursor = pFc.Search(pQf, false); IFeature pF = pFcursor.NextFeature(); IFeatureSelection pFsel = (IFeatureSelection)pFl; ISelectionSet pSel = pFsel.SelectionSet; if (pF != null) { pSel.Add(Convert.ToInt32(listBox1.SelectedItem)); ZoomToFeature(pF);//method called to zoom to feature extent. } } catch (Exception ex) { MessageBox.Show("Exception caught." + ex); } }
private void timer1_Tick(object sender, EventArgs e) { ESRI.ArcGIS.Carto.IActiveView pAV; ESRI.ArcGIS.Carto.IMap pMap; ESRI.ArcGIS.Geodatabase.IEnumFeature pEnumF; ESRI.ArcGIS.Geodatabase.IFeature pF; IDocument doc2 = m_application.Document; IMxDocument mxdoc2 = (IMxDocument)doc2; IMap map2= mxdoc2.FocusMap; ITable table = (ITable)(map2.get_Layer(0) as IFeatureSelection); QueryFilter searchFilter; double minX, minY, maxX, maxY; minX = 45600048.45; maxX = 0; minY = 80000054.56; maxY = 0; foreach (object cekirani in checkedListBox2.CheckedItems) { int d = cekirani.ToString().IndexOf(','); //MessageBox.Show(cekirani.ToString().Remove(d)); searchFilter = new QueryFilter(); searchFilter.WhereClause = "Ime='"+cekirani.ToString().Remove(d)+"'"; ICursor kursor=(ICursor)table.Search(searchFilter,true); IRow row = kursor.NextRow(); int ime=row.Fields.FindField("Ime"); int alias = row.Fields.FindField("Alias"); int iks = row.Fields.FindField("X"); int ipsilon = row.Fields.FindField("Y"); while(row!=null) { if (Convert.ToDouble(row.get_Value(iks))<minX) minX = Convert.ToDouble(row.get_Value(iks)); if (Convert.ToDouble(row.get_Value(iks))>maxX) maxX = Convert.ToDouble(row.get_Value(iks)); if (Convert.ToDouble(row.get_Value(ipsilon))<minY) minY = Convert.ToDouble(row.get_Value(ipsilon)); if (Convert.ToDouble(row.get_Value(ipsilon))>maxY) maxY = Convert.ToDouble(row.get_Value(ipsilon)); row = kursor.NextRow(); } } pMap = (IMap)map2; pEnumF = (IEnumFeature)pMap.FeatureSelection; pF = pEnumF.Next(); ESRI.ArcGIS.Geometry.IEnvelope pEnv; pEnv = new EnvelopeClass(); pEnv.SetEmpty(); pEnv.XMin = minX; pEnv.XMax = maxX; pEnv.YMin = minY; pEnv.YMax = maxY; pEnv.Expand(2.5,2.5,true); pAV = mxdoc2.ActiveView; pAV.Extent = pEnv; pAV.Refresh(); }
