marylandgis
Can't get Table to Table (Conversion) output to dBase
Discussion created by marylandgis on Mar 13, 2012
Latest reply on Mar 14, 2012 by marylandgis
The Table to Table (Conversion) tool has a parameter for Output Location of the table.  The parameter description says:
If a folder is specified, a dBASE table will be created. If a geodatabase is specified, a geodatabase table will be created.
I am directing the output to a folder called "Table", yet the output still goes to a subfolder "info" that holds files of type .dat, .nit, .dir, .xml.  I believe these are geodatabase files.
How do I force a dBase output?  Is this no longer supported but still documented?
Outcomes
