A question regarding an error message
2964
03-09-2012 06:21 PM
AnarJofaryv
I am running the VRP problem from for the file offered on the on-oline training vourse offered through ESRI. I keep getting the following message:
Warning: Impedance attribute is not time-based.
Error: Invalid context.
I redid the problem several times and each time I got the same message. Could you please help me out? Thanks.
JaySandhu
How do you create the VRP layer? Also, if you bring up the properties of the VRP layer what is the impedance attribute set to?
Jay Sandhu
NaAn
I guess your Time Attribute in Layer Properties (Analysis Settings tab) is set to empty. If that's the case, please select a time attribute from the drop-down list.
Thanks.
Anna
