Hi,If you have 3D Analyst extension then you could use the Add Surface Information Tool (ArcToolbox > 3D Analyst Tools > Functional surface)The Add Surface Information Tool will add Min/Max/Avg slope to a line.If you do not have 3D Analyst extension but only Spatial Analyst extension then use your DEM create a slope using the Slope tool (ArcToolbox > Spatial Analyst tools > Surface). Then convert your polyline to points. Use Extract Values To Points(ArcToolbox > Spatial Analyst tools > Extraction) on the Slope Raster. This will give the Slope values for these points and then you could perform a join between points and the polyline. -Gayu
