vasilestan
Calculate Surface of a Watersheed in relation with DEM
Discussion created by vasilestan on Mar 7, 2012
Latest reply on Mar 7, 2012 by m.gasior
I've tried to calculate the surface of a watershed using this method http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Polygon_Volume/00q90000003q000000/
And i have some error
>>> # Import system modules
... import arcpy
... from arcpy import env
... # Obtain a license for the ArcGIS 3D Analyst extension
... arcpy.CheckOutExtension("3D")
... # Set environment settings
... env.workspace = "d:/.../Volume"
... # Set Local Variables
... inSurface = "D:\...\gdem"
... inPoly = "D:\...\Watershed"
... zField = "Height"
... refPlane = "BELOW"
... volFld = "Volume"
... sAreaFld = "SArea"
... #Execute PolygonVolume
... arcpy.PolygonVolume_3d(inSurface, inPoly, zField, refPlane, volFld, sAreaFld)
Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000732: Input Surface: Dataset D:\...\gdem does not exist or is not supported
The dem is there but is not recognized.
What should be the cause?
There are any other method to calculate the surface of a polygon in relation with DEM.
Outcomes
