navjohn
ArcScene startup Event Handler
Discussion created by navjohn on Mar 6, 2012
Hi Guys,
I don't have a lot of experience with Event Handlers but I am trying to fire a sub (ShutDown_Maintenance) when an ArcScene document is closed.
The problem I am having is that when adding the handler I can't find anything which will ctype to an SxDocumentEventsHelper
Public m_pApp As IApplication
Public m_pAppEvents As ESRI.ArcGIS.ArcScene.SxDocumentEventsHelper
public sub StartUp()
     ' Set the Close Event handler
     m_pAppEvents = New ESRI.ArcGIS.ArcScene.SxDocumentEventsHelper
     AddHandler CType(?????, ESRI.ArcGIS.ArcScene.SxDocumentEventsHelper).BeforeCloseDocument, AddressOf modMain.ShutDown_Maintenance
End Sub
I tried to follow the code at:
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/How_to_wire_custom_events_using_IActiveViewEvents/000100000440000000/
but got errors at the line:
m_pAppEvents = New ESRI.ArcGIS.ArcScene.SxDocumentEventsHelper(addressof modmain.ShutDown_Maintenance)
- New does not have two parameters.
Can anyone tell me how this works?
John
Outcomes
