hi, all I am trying to delete row from file geodatabase table using following code:
import arcpy
import math
arcpy.env.workspace = r'C:\TempArcGISCalculate\Scratch.gdb'
intable="Section0011"
Statstbl="C:/TempArcGISCalculate/Scratch.gdb/S11FirstStats"
Query = '"FREQUENCY"=1'
records = arcpy.SearchCursor(Statstbl,Query)
singlelst = []
for record in records:
singlelst.append(record.getValue('Trace')) # it adds data who has single point only
del records
del record
pts = arcpy.UpdateCursor(intable)
for pt in pts:
for i in singlelst:
if pt.Trace == int(i):
print "Deleting:", pt.OBJECTID, pt.Trace
pts.deleteRow(pt)
del pts, pt
In the table "Section0011", I have 534975 rows. When the script runs, it only remove about 1000 rows in couple hours, but has not finished yet. Is there any fast way to run deleteRow? please helpThanks lot
