When creating a simple map in a UIView controller I seem to be getting a memory leak when the map initializes. The leak according to Instruments is coming from the AGSSBJsonStreamParser init method.
Once the map loads I can pan and zoom without further leaks.
Now if I add geocoding I get the same leak (AGSSBJsonStreamParser) after each geocode session. The single leak at startup seems minor but when doing a considerable amount of geocoding the leaked memory starts to add up. Has anyone encountered this issue?
