Hello All,
I am building a model and would like to use the "Select By Attribute" tool on the output raster from a raster calculation. However, when I try to connect the output raster to the "Select By Attribute" tool, it does not recognize the raster as a valid input (I am only given the Environments and Precondition choices). Is this because the model has not been run yet? If I run the model up to the raster calculation, will I then be able to connect the output raster to the "Select By Attribute" tool. I know this is an elementary question, but the datasets are large and I want to avoid running the model partially if not necessary.
thanks,
mike
