alinktbsl-bz-esridist
Help with javascript in Elections Results Viewer Template
Discussion created by alinktbsl-bz-esridist Employee on Mar 5, 2012
I need help with the Election Results Viewer Template which is a java-script app.  I modified the config.js by replacing the default services to my services, which i loaded up on our local server and I have also entered a bing map code.  When i opened the App, the web map services i added in the config.js does not display.
I have the projection set to WGS 1984 Web Mercator Auxillary Sphere and also set the Tiling Schema.
Any inputs??
Globaldomination
Outcomes
