jenniewng11
How to convert GCS_WGS_1984 to WGS 84
Discussion created by jenniewng11 on Mar 5, 2012
Latest reply on Mar 5, 2012 by jenniewng11
Does any one how to convert
original system
Geographic Coordinate System: GCS_WGS_1984
Datum:  D_WGS_1984
Prime Meridian:  Greenwich
Angular Unit:  Degree
to
target system
Projected Coordinate System: WGS 84 / UTM zone 54N
Projection: Transverse_Mercator
false_easting: 500000.00000000
false_northing: 0.00000000
central_meridian: 141.00000000
scale_factor: 0.99960000
latitude_of_origin: 0.00000000
Linear Unit:  m
Geographic Coordinate System: WGS 84
Datum:  World Geodetic System 1984
Angular Unit:  degree
I used the Projected Coordinate System: WGS_1984_UTM_Zone_54N. The results is pasted as below. However, it doesn't line up with the shapfile which has the targeted system.
False_Easting: 500000.00000000
False_Northing: 0.00000000
Central_Meridian: 141.00000000
Scale_Factor: 0.99960000
Latitude_Of_Origin: 0.00000000
Linear Unit:  Meter
Datum:  D_WGS_1984
I'd appreciate any help you might give me.
Jennie
Outcomes
