hughgrant
Change Zoom Slider Labels
Discussion created by hughgrant on Mar 1, 2012
Latest reply on Mar 13, 2012 by stevel
I have seen lot's of information on changing the zoom slider using the esri default methods, but I'm looking to do something different and can't see from the API how I should do it. I have several hierachies of boundaries that I want to display. The user selects which Hierarchy from a drop down box. At various zoom levels only a given layer in that hierachy is displayed. For example if the zoom level is 0 to 5 show state borders, when a bit lower show local givernment borders, etc etc. What I can't see how to do is update the zoom slider labels. I can set them before I create the map, but can't see how to change them on the fly afterwards, as the user changes which hierarchy they are looking at. I want to have the labels represent which boundaries are visible at a given zoom level. Does anyone know if this is possible? If so could you show me which object.method(newLabelInfo) to use?
Outcomes
