And I've tried it out and found out that this was what I needed. So what i've done was edit the model with my own input feature class and so on. Though my first try was with a shapefile and it worked fine. Second try was with a file geodatabase but here is where all my problems begin. (Don't have alot of python knowledge)
The error that i'm getting is: updateParameters Execution Error: Runtime error : FilterObject: illegal list value After some troubleshooting I've found out that: The length of the field that i want to get the list from it it's too long. It's a text field and its length is 100. So I added a new field and set the length of it to 2 and calculated the values of the old field to the new one. With this done it does run fine. But I want it for to run fine with a text field with a length 50.
Is there something I need to do with the validation code for it to run fine?
