Hello! I have a script which combs a geodatabase and returns each feature class and feature dataset which uses a domain, the name of the domain, and to which field the domain is applied. When it hits a feature dataset with a subtype, it only lists the domains in use by the default subtype value, not the domains associated with the other subtype values. How can I write a script which will list the domains set for each individual subtype in a feature dataset? Thank you!
import arcpy
#Set workspace environment to geodatabase
arcpy.env.workspace = r"\\Gissrv1\017gisdatt\017GISDATA\Geodatabases\NDOT_Transportation.gdb"
#Get list of feature classes in geodatabase
FCs = arcpy.ListFeatureClasses()
#Loop through feature classes in list
for FC in FCs:
#List fields in feature class
fields = arcpy.ListFields(FC)
#Loop through fields
for field in fields:
#Check if field has domain
if field.domain != "":
#Print feature class, field, domain name
print FC, ",", field.name, ",", field.domain
#Get list of feature datasets in geodatabase
FDs = arcpy.ListDatasets("*", "Feature")
#Loop through feature datasets in list
for FD in FDs:
#List fields in feature dataset
fields = arcpy.ListFields(FD)
print FD, ",", field.name, ",", field.domain
