smilmaster
select by attribute with a loop
Discussion created by smilmaster on Feb 23, 2012
Latest reply on Feb 23, 2012 by smilmaster
Hi everybody,
I have a polygon shipfile with thousand objects and each has a sole value stored in a field. The values are stored in
order, for example, 1, 2,3,4, ...... I want to generate new shipfiles each with only one object. This can be done by
select tool under the Extract toolbox. As i have thousands objects, using the toolbos is time consuming. I believe
python can do this work well with a loop. however, i am a beginner, and not familar with it. I spent a whole day to try
fullfilling this work but failed. Can anybody help me write the code? Or give me some tips. Thank you very much in
advance
the code for the select is like:
arcpy.Select_analysis("C:/majorrds.shp", "C:/output/majorrdsClass4.shp", '"CLASS" = '4'')  Can we change the
number "4" automatically with a loop? and how? Thank you!
Sincerely Xiaoma Li
Outcomes
