Here is a similar problem I had a long time ago. I needed to draw a right angled line across the road at each drain (cunvert) point that was recorded in an asset management system. ArcIMS could not handle linear referencing. I got the angles by using MakeRouteEventLayer, then it was just a matter of creating a new line.It could be a lot more elegant at 10.x but the maths is the same. I wrote out to a file and used the sample/CreateFeaturesFromTextFile, now deprecated and removed.
# culvert.py
# create culvert lines from point events
# must have loc_angle and length_m fields
# default length_m is 10 metres
# angle is from event wizard which is parallel to road
# which must be wrong at 9.1
# Input
# arg1 point event layer
# arg2 loc_angle field
# arg3 length_m field
# arg4 output featureclass
# projection from event layer
# Kim Ollivier
# 26 September 2006
import sys, string, os, win32com.client, math
def newculvert(strID,strX,strY,strAngle,strSize) :
Create a line array at right angles to angle
and add to new featureclass already defined
id = int(strID)
x0 = float(strX)
y0 = float(strY)
radAngle = float(strAngle) / 180.0 * 3.14159
size = float(strSize) / 2.0
if size == 0 :
size = 10
x1 = x0 - size * math.cos(radAngle)
y1 = y0 - size * math.sin(radAngle)
x2 = x0 + size * math.cos(radAngle)
y2 = y0 + size * math.sin(radAngle)
# print "%8d %12.3f %12.3f %8.3f %4.1f" % (id,x0,y0,angle,size)
# print " %12.3f %12.3f %12.3f %12.3f" % (dx1,dy1,dx2,dy2)
print >> f1,"%d 0" % id
print >> f1,"0 %f %f 0.0 0.0" % (x1,y1)
print >> f1,"1 %f %f 0.0 0.0" % (x2,y2)
return True
#----------------- main -----------------
gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
if len(sys.argv) != 6 :
print "Need 6 parameters, setting defaults for debugging"
strInputFeatureClass = "e:/council/clutha/shape/culvert3.shp"
strIDField = "DRAIN_ID"
strAngleField = "LOC_ANGLE"
strSizeField = "LENGTH_M"
strOutputFeatureClass = "e:/council/clutha/shape/culvert_ln.shp"
else :
strInputFeatureClass = sys.argv[1]
strIDField = sys.argv[2]
strAngleField = sys.argv[3]
strSizeField = sys.argv[4]
strOutputFeatureClass = sys.argv[5]
if not os.path.exists(strInputFeatureClass) :
print strInputFeatureClass,"not found"
sys.exit()
# set the directory and workspace to the source shapefile location
os.chdir(os.path.dirname(strInputFeatureClass))
gp.Workspace = os.path.dirname(strInputFeatureClass)
f1 = open("culvert.txt","w")
print >> f1,"Polyline"
# Find the name of the shape field using Describe.
strShapeFieldName = gp.Describe(strInputFeatureClass).ShapeFieldName
# Check other fields are correct
eFlds = gp.ListFields(strInputFeatureClass)
fld = eFlds.Next()
fldOk = False
print gp.GetCount_management(strInputFeatureClass),"gp count"
while fld :
if fld.Name.upper() == strIDField.upper() :
fldIDOk = True
if fld.Name.upper() == strAngleField.upper() :
fldAngleOk = True
if fld.Name.upper() == strSizeField.upper() :
fldSizeOk = True
fld = eFlds.Next()
if not fldIDOk:
strErr = "No ID field found "+strIDField
gp.AddError(strErr)
print strErr
else :
print strIDField," found"
if not fldAngleOk:
strErr = "No Angle field found "+strAngleField
gp.AddError(strErr)
print strErr
else :
print strAngleField," found"
if not fldSizeOk:
strErr = "No Size field found "+strSizeField
gp.AddError(strErr)
print strErr
else :
print strSizeField," found"
if not (fldIDOk or fldAngleOk or fldSizeOk) :
print "Fatal error in field names"
sys.exit(2)
nCulvert = 0
# open a Search Cursor
objRowList = gp.SearchCursor(strInputFeatureClass)
objRow = objRowList.Next()
try :
while objRow:
objGeometry = objRow.GetValue(strShapeFieldName)
objPart = objGeometry.GetPart(0)
strX = objPart.X
strY = objPart.Y
strID = objRow.getValue(strIDField)
strAngle = objRow.GetValue(strAngleField)
strSize = objRow.GetValue(strSizeField)
# create a new line feature
ok = newculvert(strID,strX,strY,strAngle,strSize)
if ok :
nCulvert += 1
# cleanup or looks like a memory leak
del objRow, objPart, objGeometry
except Exception, e :
print e
gp.AddError(e)
print "Error in Search Cursor"
print gp.GetMessages()
gp.AddError("Error in Search Cursor")
sys.exit(2)
print >> f1,"END"
f1.close()
print nCulvert,"culverts total"
gp.AddMessage(str(nCulvert)+" culverts found")
# create a shapefile
gp.OverwriteOutput = 1
test = "culvert_ln.shp"
gp.CreateFeaturesFromTextFile("culvert.txt",".",test,"")
print "Created new shapefile",test
