Assign topology rules to existing shapefile?
446
02-15-2012 12:03 PM
RileyMulligan
Hi, I've imported a file into ArcMap 10 and the shapefile consists of polygons, but there are some minor overlaps and some small gaps. Separately, i've created a new geodatabase and topology file, but I don't know how to (or if i can) apply the rules i set in my topology file to the existing shapefile. Any ideas?
Ri
RichardFairhurst
MVP Honored Contributor
Ri
An actual shapefile (ending in .shp) cannot be used with topology.  It can be copy/imported into the geodatabase you have created and the data would then become a feature class of the geodatabase.  That new feature class can be configured to use the topology rules you have set up and be validated to check for topology errors.
