rami_mk
add globeControl to arcmap
Discussion created by rami_mk on Feb 6, 2012
i'm using arcgis\engine 9.3 with .net c# language.
i'm trying to add some custom 3d capabilities to arcmap,
my current step is to synchronize between the 2d arcmap view and the 3d globecontrol view.
but i'm facing some difficulties :(
arcmap needs center point and scale,
i'm setting the center point to axGlobeControl.GlobeDisplay.ActiveViewer.Camera.Target
but how to set scale?
currently i'm using this code:
but it doesnt give the expected behavior.
        void SetMapView(object sender, ESRI.ArcGIS.Geometry.IPoint TgtPoint, ESRI.ArcGIS.Geometry.IPoint ObsPoint, double spaceLeng)
            try
                ArcMap.Document.ActiveView.Activate(ArcMap.Application.hWnd);
                ESRI.ArcGIS.Geometry.IPoint[] points = new ESRI.ArcGIS.Geometry.IPoint[2];
                points[0] = ObsPoint;
                points[1] = TgtPoint;
                ESRI.ArcGIS.Geometry.Envelope newExtent = new ESRI.ArcGIS.Geometry.Envelope();
                newExtent.DefineFromPoints(ref points);
                newExtent.CenterAt(TgtPoint);
                ArcMap.Document.ActiveView.Extent = (ESRI.ArcGIS.Geometry.IEnvelope)newExtent;
                m_map.MapScale = spaceLeng * 100000; // 100000 is for test
                ArcMap.Document.ActiveView.Refresh();
                //ArcMap.Document.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeography, null, null);
            catch (Exception ex)
                System.Windows.Forms.MessageBox.Show(ex.Message);
TgtPoint = axGlobeControl.GlobeDisplay.ActiveViewer.Camera.Target
ObsPoint = axGlobeControl.GlobeDisplay.ActiveViewer.Camera.Observer
spaceLeng = axGlobeControl.GlobeDisplay.ActiveViewer.Camera.ViewingDistance
- axGlobeControl.GlobeDisplay.ActiveViewer.Camera.ViewingDistance is not effected when zoom in and out
- when the camera is not vertical above the globe surface  the "newExtent" in the previous code gives view that is zoomed in or out more than wanted.
thanks in advance.
Outcomes
