pamorrison
Adjusting line spacing in a text box
Discussion created by pamorrison on Feb 4, 2012
Latest reply on Feb 24, 2012 by pamorrison
I was wondering if it is possible to adjust the line spacing within a text box in ArcMap 9.3.  I've created text boxes on the Layout view to hold company info, map info, scale, etc.  In one particular box, I have 7 lines.  I have adjusted the font size and type (i.e. bold and italics) of individual lines using formatting tags.  However, I would like to adjust the spacing between the lines.  Rather than have them all spaced out evenly, I would like a group of them (the company address and contact info) spaced a little closer together and another line set a little farther apart from the others.  In MSWord you can add space before or after a paragraph or you can make the line spacing a multiple (i.e. 1.5).  Is there a way to do that in ArcMap 9.3?
Thanks.
Outcomes
