strider8
What does the Identify Operation do When we pass an Envelope or Polygon?
Discussion created by strider8 on Feb 2, 2012
Latest reply on Feb 3, 2012 by svinnakota-esristaff
We were running an Idetify task from our Flex App, when we saw a strange result. Ife we pass in a point while identifying, we got more results than if we pass in a bigger envelope, or buffer around our points. We found that this results is reproducable when we query the rest end point.
Suppose I want to identify the traffic Camera at the Location of (-85.8117346379999, 38.274177432) on the Louisville Map service (http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/MapServer),
we get the following results :
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/MapServer/identify?geometryType=esriGeometryPoint&geometry=-85.8117346379999%2C+38.274177432&sr=4326&layers=2&time=&layerTimeOptions=&layerdefs=&tolerance=1&mapExtent=-85.9880280067818%2C37.8956514753086%2C-85.3325637450334%2C38.5511157370571&imageDisplay=400%2C400%2C96&returnGeometry=true&maxAllowableOffset=&f=HTML
You will see that you get one traffic cam (Object Id=2).
Now if I pass an enevelope around this point of (-85.8, 38.2,-85.82, 38.3), we get the following result
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/MapServer/identify?geometryType=esriGeometryEnvelope&geometry=-85.805%2C+38.2%2C-85.815%2C+38.3&sr=4326&layers=2&time=&layerTimeOptions=&layerdefs=&tolerance=1&mapExtent=-85.9880280067818%2C37.8956514753086%2C-85.3325637450334%2C38.5511157370571&imageDisplay=400%2C400%2C96&returnGeometry=true&maxAllowableOffset=&f=HTML
You will see that now you get one result, but this is a different Cam (Object Id=47)
Why does the Identify operation return such an unexpected result?
Outcomes
