update field records
492
01-31-2012 10:38 AM
RameshGautam
I have two shape files. They are: (i) WashingtonA and (ii) WashingtonB. WashingtonB is a subset of WashingtonA. During processing, additional records were added in WashingtonB. These records were generated by dividing the existing polygons of WashingtonB. Now, I want to update WashingtonA based on updated polygons of WashingtonB. Can you please help me how to do this using Python code? Thanks
JakeSkinner
Esri Esteemed Contributor
Below is an example on how I was able to accomplish this.  The OBJECTIDs for the two feature classes were the same, so I first appended all the new features created for a polygon split.  Then I compare the original geometry to each geometry in the subset feature class (excluding new features).  If the geometry is different, I delete the original feature and update with the new feature (the other half of the geometry that was created from the polygon split).  Since I used the OBJECTID I can only run this script once as the OBJECTIDs in the original feature class will change after the appends.
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python\test.gdb"
env.overwriteOutput = True
fcA = "AirportsA"
fcB = "AirportsB"
OID_list = []
listB = []
# find max OBJECTID
rows = arcpy.SearchCursor(fcA)
for row in rows:
    OID_list.append(row.OBJECTID)
del row, rows
maxOID = sorted(OID_list)[-1]
# append all geometries for AirportsB to list
rows = arcpy.SearchCursor(fcB)
for row in rows:
    geom = row.Shape
    listB.append(geom.area)
del row, rows
# append all new features to AirportsA feature class
arcpy.MakeFeatureLayer_management(fcB, "AirportsB_lyr", "OBJECTID > " + str(maxOID))
arcpy.CopyFeatures_management("AirportsB_lyr", "AirportsB_2")
arcpy.Append_management("AirportsB_2", fcA, "NO_TEST")
x = 0
# compare geometries from AirportsA to AirportsB
rows = arcpy.SearchCursor(fcA, "OBJECTID <= " + str(maxOID))
for row in rows:
    geom = row.Shape
    if geom.area != listB:
        print "OBJECTID " + str(row.OBJECTID) + " has changed"
        arcpy.MakeFeatureLayer_management(fcA, "AirportsA_lyr")
        arcpy.SelectLayerByAttribute_management("AirportsA_lyr", "NEW_SELECTION", "OBJECTID = " + str(row.OBJECTID))
        # delete original features that changed
        arcpy.DeleteFeatures_management("AirportsA_lyr")
        arcpy.MakeFeatureLayer_management(fcB, "AirportsB_lyr", "OBJECTID = " + str(row.OBJECTID))
        # append new split feature
        arcpy.Append_management("AirportsB_lyr", fcA, "NO_TEST")
        x += 1
del row, rows
RameshGautam
Thanks a lot for your help. I apprecaite it. Let me try and see how it goes.
import arcpy
fcA = "AirportsA"
fcB = "AirportsB"
OID_list = []
listB = []
# find max OBJECTID
for row in rows:
del row, rows
for row in rows:
    geom = row.Shape
del row, rows
x = 0
for row in rows:
    geom = row.Shape
        x += 1
del row, rows
