I am developing an editor extension for ArcMap. The extension should forbid changes to features, which have a attribute value "deny" in a column to restrict any change to the feature. Therefore I check on every OnChangeFeature event if the feature has the attribute value "deny". If this is the case, the change has to be aborted. But when I call IEditor.AbortOperation(), a message box is displayed, for example "The feature(s) could not be moved. Failed to move related features [FeatureClass]" when moving a feature. Is there a way to get rid of that massage box or at least to customize the text?#region IExtension Implementations
public void Shutdown()
_editor = null;
_editEvents = null;
public string Name
get { return "ValidateFeatures_Extension"; }
public void Startup(ref object initializationData)
if (initializationData != null && initializationData is IEditor)
_editor = (IEditor)initializationData;
//Wire editor events.
_editEvents = (IEditEvents_Event)_editor;
_editEvents.OnStartEditing += EditEventsOnStartEditing;
#endregion
#region Editor event notification implementation
private void EditEventsOnStartEditing()
if (_editor.EditWorkspace.Type == esriWorkspaceType.esriFileSystemWorkspace)
return;
_editEvents.OnChangeFeature += EditEventsOnChangeFeature;
_editEvents.OnCreateFeature += EditEventsOnCreateFeature;
private void EditEventsOnChangeFeature(IObject obj)
Validate(obj as IFeature);
private void EditEventsOnCreateFeature(IObject obj)
#endregion
private void Validate(IFeature inFeature)
var fieldIndex = inFeature.Fields.FindField("DENYCHANGES");
if (fieldIndex < 0)
return;
if (inFeature.Value[fieldIndex].Equals("deny"))
_editor.AbortOperation();
