I got a problem with IContentView3. I created a custom crontrol that implements IContentView3.
When I Add that ContentView with the AddContentsView method, I Got a system.NotImplementedException : Method or operation not implemented.
AddContentsView method takes has an IContentView parameter. Do I have to cast the IContentView3 control ?
Thank you verru much ...
Dim ContentsView As ESRI.ArcGIS.ArcMapUI.IContentsView
ContentsView = New ESRI.ArcGIS.ArcMapUI.TOCDisplayView
Dim ContentsViewEdit As ESRI.ArcGIS.ArcMapUI.IContentsViewEdit
ContentsViewEdit = DirectCast(VDQ.SDDI.EsriLib.ArcObjects.IU.ArcMap.EnvironnementArcMap.Instance.Application.Document, ESRI.ArcGIS.ArcMapUI.IContentsViewEdit)
ContentsView = New MyContentView <---- IContentView3 Control
ContentsViewEdit.AddContentsView(ContentsView) <----------------------- System.NotImplementedException
Public Class MyContentView
Implements ESRI.ArcGIS.ArcMapUI.IContentsView3
Private Declare Ansi Function ShowWindow Lib "user32" (ByVal hwnd As Int32, ByVal nCmdShow As Int32) As Int32
Private Const SW_HIDE As Integer = 0
Private Const SW_SHOW As Integer = 9
#Region "Variables"
Private m_UserControl As VDQ.SDDI.Localisation.IU.Windows.Localisation
#End Region
#Region "Conctructeur"
Public Sub New()
m_UserControl = New VDQ.SDDI.Localisation.IU.Windows.Localisation(VDQ.SDDI.EsriLib.ArcObjects.IU.ArcMap.ContexteApplication.Instance)
End Sub
#End Region
Public Sub Activate(parentHWnd As Integer, Document As ESRI.ArcGIS.ArcMapUI.IMxDocument) Implements IContentsView.Activate, IContentsView2.Activate, IContentsView3.Activate
ShowWindow(m_UserControl.Handle.ToInt32, SW_SHOW)
End Sub
Public Sub AddToSelectedItems(item As Object) Implements IContentsView.AddToSelectedItems, IContentsView2.AddToSelectedItems, IContentsView3.AddToSelectedItems
End Sub
Public Sub BasicActivate(parentHWnd As Integer, Document As ESRI.ArcGIS.Framework.IDocument) Implements IContentsView2.BasicActivate, IContentsView3.BasicActivate
End Sub
Public Property ContextItem As Object Implements IContentsView.ContextItem, IContentsView2.ContextItem, IContentsView3.ContextItem
Get
Return Nothing
End Get
Set(value As Object)
End Set
End Property
Public Sub Deactivate() Implements IContentsView.Deactivate, IContentsView2.Deactivate, IContentsView3.Deactivate
ShowWindow(m_UserControl.Handle.ToInt32, SW_HIDE)
End Sub
Public ReadOnly Property hWnd As Integer Implements IContentsView.hWnd, IContentsView2.hWnd, IContentsView3.hWnd
Get
Return m_UserControl.Handle.ToInt32
End Get
End Property
Public ReadOnly Property Name As String Implements IContentsView.Name, IContentsView2.Name, IContentsView3.Name
Get
Return "Localisation"
End Get
End Property
Public WriteOnly Property ProcessEvents As Boolean Implements IContentsView.ProcessEvents, IContentsView2.ProcessEvents, IContentsView3.ProcessEvents
Set(ByVal value As Boolean)
End Set
End Property
Public Sub Refresh(item As Object) Implements IContentsView.Refresh, IContentsView2.Refresh, IContentsView3.Refresh
End Sub
Public Sub RemoveFromSelectedItems(item As Object) Implements IContentsView.RemoveFromSelectedItems, IContentsView2.RemoveFromSelectedItems, IContentsView3.RemoveFromSelectedItems
End Sub
Public Property SelectedItem As Object Implements IContentsView.SelectedItem, IContentsView2.SelectedItem, IContentsView3.SelectedItem
Get
Return Nothing
End Get
End Set
End Property
Public Property ShowLines As Boolean Implements IContentsView.ShowLines, IContentsView2.ShowLines, IContentsView3.ShowLines
Get
End Get
Set(value As Boolean)
End Set
End Property
Public ReadOnly Property Bitmap As Integer Implements IContentsView3.Bitmap
Get
Dim bitmapResourceName As String = Me.GetType().Name + ".bmp"
Dim bmp As System.Drawing.Bitmap = New System.Drawing.Bitmap(Me.GetType(), bitmapResourceName)
bmp.MakeTransparent(bmp.GetPixel(1, 1)) 'Utilise un png aléatoire avec transparence
Return bmp.GetHbitmap().ToInt32()
End Get
End Property
Public ReadOnly Property Tooltip As String Implements IContentsView3.Tooltip
Get
End Get
End Property
Public Property Visible As Boolean Implements IContentsView.Visible, IContentsView2.Visible, IContentsView3.Visible
Get
Return True
End Get
End Set
End Property
End Class
