I have a .mxd file with VBA programmed by a long-gone programmer. It uses the Application object. The code worked fine in ArcGIS 9 and in 10 until recently. The only changes made since the move to ver. 10 were schema changes in the data tables.
First error: ???Compile error: Method or data member not found??? occurred in the bolded code below:
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pFeatSel As IFeatureSelection
Dim pQueryFilt As IQueryFilter
Dim pSelSet As ISelectionSet
Dim pLayer As IFeatureLayer
Set pMxDoc = Application.Document
Set pMap = pMxDoc.FocusMap
Set pLayer = FindLayer("Parcels")
Set pFeatSel = pLayer
I changed Application .document to ThisDocument and it worked for that line of code, but then I got this error a few lines later:
???Compile error: Invalid use of property??? See bolded code below:
Dim pStatusBar As IStatusBar
Dim pProgbar As IStepProgressor
Set pStatusBar = Application.StatusBar
Set pProgbar = pStatusBar.ProgressBar
pProgbar.Position = 0
Any ideas?
There are no missing references. Does the priority order of references make a difference?
