plambert75
Shapefile and image mismatch
Discussion created by plambert75 on Jan 19, 2012
Latest reply on Oct 2, 2016 by kiwi_chick_2882
Hi
I'm attempting to use CityEngine 2011 to create a model of Singapore. I have a satellite image of the downtown area of Singapore along with a shapefile containing the road networks. Both are in WGS84 UTM zone 48N projection and when viewed in ArcMap they correlate perfectly. However, when I import them into CityEngine they end up seperated by about 400km and 90 degrees rotation. I can use the map offset to bring the map layer into the same area as the shapefile road network but can do anything about the rotation. I guess I therefore have 2 questions:
1. Why don't the two sets of data correlate correctly in CityEngine?
2. Is there any way I can rotate the map layer so I can at least get the image and the road network data lined up?
Thanks.
Outcomes
