bmgustafson
Error Loading Map
Discussion created by bmgustafson on Jan 18, 2012
Latest reply on Jan 30, 2012 by spoiledtechie
I get this crash dump every time I try and load a map in an android application weather use a sample or build it from scratch.  What am I missing here?
01-18 13:52:27.065: D/dalvikvm(276): Trying to load lib /data/data/com.TSGT.MapApp/lib/libGLMapCore.so 0x44ede968
01-18 13:52:29.055: D/dalvikvm(276): Added shared lib /data/data/com.TSGT.MapApp/lib/libGLMapCore.so 0x44ede968
01-18 13:52:29.095: I/GLMapCore(276): VectorPipeline: API Level = 8, VBO Deactived
01-18 13:52:31.495: D/libEGL(276): egl.cfg not found, using default config
01-18 13:52:31.505: D/libEGL(276): loaded /system/lib/egl/libGLES_android.so
01-18 13:52:31.575: W/dalvikvm(276): threadid=7: thread exiting with uncaught exception (group=0x4001d800)
01-18 13:52:31.595: E/AndroidRuntime(276): FATAL EXCEPTION: GLThread 8
01-18 13:52:31.595: E/AndroidRuntime(276): java.lang.IllegalArgumentException: No configs match configSpec
01-18 13:52:31.595: E/AndroidRuntime(276):  at com.esri.android.map.MapSurface$a.chooseConfig(Unknown Source)
01-18 13:52:31.595: E/AndroidRuntime(276):  at android.opengl.GLSurfaceView$EglHelper.start(GLSurfaceView.java:916)
01-18 13:52:31.595: E/AndroidRuntime(276):  at android.opengl.GLSurfaceView$GLThread.guardedRun(GLSurfaceView.java:1246)
01-18 13:52:31.595: E/AndroidRuntime(276):  at android.opengl.GLSurfaceView$GLThread.run(GLSurfaceView.java:1116)
01-18 13:52:47.525: E/ArcGIS(276): url =http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer
01-18 13:52:47.525: E/ArcGIS(276): java.net.UnknownHostException: services.arcgisonline.com
01-18 13:52:47.525: E/ArcGIS(276):  at java.net.InetAddress.lookupHostByName(InetAddress.java:513)
01-18 13:52:47.525: E/ArcGIS(276):  at java.net.InetAddress.getAllByNameImpl(InetAddress.java:278)
01-18 13:52:47.525: E/ArcGIS(276):  at java.net.InetAddress.getAllByName(InetAddress.java:242)
01-18 13:52:47.525: E/ArcGIS(276):  at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:136)
01-18 13:52:47.525: E/ArcGIS(276):  at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:164)
01-18 13:52:47.525: E/ArcGIS(276):  at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:119)
01-18 13:52:47.525: E/ArcGIS(276):  at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:348)
01-18 13:52:47.525: E/ArcGIS(276):  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:555)
01-18 13:52:47.525: E/ArcGIS(276):  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:653)
01-18 13:52:47.525: E/ArcGIS(276):  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:627)
01-18 13:52:47.525: E/ArcGIS(276):  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:616)
01-18 13:52:47.525: E/ArcGIS(276):  at com.esri.core.internal.b.a.e.a(Unknown Source)
01-18 13:52:47.525: E/ArcGIS(276):  at com.esri.core.internal.a.a.m.b(Unknown Source)
01-18 13:52:47.525: E/ArcGIS(276):  at com.esri.android.map.ags.ArcGISDynamicMapServiceLayer.initLayer(Unknown Source)
01-18 13:52:47.525: E/ArcGIS(276):  at com.esri.android.map.ags.ArcGISDynamicMapServiceLayer$1.run(Unknown Source)
01-18 13:52:47.525: E/ArcGIS(276):  at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
01-18 13:52:47.525: E/ArcGIS(276):  at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
01-18 13:52:47.525: E/ArcGIS(276):  at java.util.concurrent.FutureTask.run(FutureTask.java:137)
01-18 13:52:47.525: E/ArcGIS(276):  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1068)
01-18 13:52:47.525: E/ArcGIS(276):  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:561)
01-18 13:52:47.525: E/ArcGIS(276):  at java.lang.Thread.run(Thread.java:1096)
Outcomes
