You can create custom zoomin tool that inherits from itool and customize the cursor. Replace ControlsMapZoomInToolClass with custom zoom in tool.
using System;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.Controls;
using ESRI.ArcGIS.Display;
using ESRI.ArcGIS.SystemUI;
using ESRI.ArcGIS.ADF.CATIDs;
using System.Runtime.InteropServices;
namespace PanZoom
[ClassInterface(ClassInterfaceType.None)]
[Guid("2C214724-BFA2-4e8c-BC5D-775C67FA6F51")]
public class ZoomIn : ICommand, ITool
#region COM Registration Function(s)
[ComRegisterFunction()]
[ComVisible(false)]
static void RegisterFunction(Type registerType)
// Required for ArcGIS Component Category Registrar support
ArcGISCategoryRegistration(registerType);
// TODO: Add any COM registration code here
[ComUnregisterFunction()]
[ComVisible(false)]
static void UnregisterFunction(Type registerType)
ArcGISCategoryUnregistration(registerType);
// TODO: Add any COM unregistration code here
#region ArcGIS Component Category Registrar generated code
/// <summary>
/// Required method for ArcGIS Component Category registration -
/// Do not modify the contents of this method with the code editor.
/// </summary>
private static void ArcGISCategoryRegistration(Type registerType)
string regKey = string.Format("HKEY_CLASSES_ROOT\\CLSID\\{{{0}}}", registerType.GUID);
ControlsCommands.Register(regKey);
/// <summary>
/// Required method for ArcGIS Component Category unregistration -
/// </summary>
private static void ArcGISCategoryUnregistration(Type registerType)
ControlsCommands.Unregister(regKey);
#endregion
#endregion
[DllImport("gdi32.dll")]
static extern bool DeleteObject(IntPtr hObject);
private System.Drawing.Bitmap m_bitmap;
private IntPtr m_hBitmap;
private IHookHelper m_pHookHelper;
private INewEnvelopeFeedback m_feedBack;
private IPoint m_point;
private Boolean m_isMouseDown;
private System.Windows.Forms.Cursor m_zoomInCur;
private System.Windows.Forms.Cursor m_moveZoomInCur;
public ZoomIn()
//Load resources
string[] res = GetType().Assembly.GetManifestResourceNames();
if(res.GetLength(0) > 0)
m_bitmap = new System.Drawing.Bitmap(GetType().Assembly.GetManifestResourceStream(GetType(), "ZoomIn.bmp"));
if(m_bitmap != null)
m_bitmap.MakeTransparent(m_bitmap.GetPixel(1,1));
m_hBitmap = m_bitmap.GetHbitmap();
m_pHookHelper = new HookHelperClass ();
~ZoomIn()
if(m_hBitmap.ToInt32() != 0)
DeleteObject(m_hBitmap);
#region ICommand Members
public void OnClick()
public string Message
get
return "zooms the Display In By Rectangle or Single Click";
public int Bitmap
get
return m_hBitmap.ToInt32();
public void OnCreate(object hook)
m_pHookHelper.Hook = hook;
m_zoomInCur = new System.Windows.Forms.Cursor(GetType().Assembly.GetManifestResourceStream(GetType(), "ZoomIn.cur"));
m_moveZoomInCur = new System.Windows.Forms.Cursor(GetType().Assembly.GetManifestResourceStream(GetType(), "MoveZoomIn.cur"));
public string Caption
get
return "Zoom In";
public string Tooltip
get
return "Zoom In";
public int HelpContextID
get
// TODO: Add ZoomIn.HelpContextID getter implementation
return 0;
public string Name
get
return "Sample_Pan/Zoom_Zoom In";
public bool Checked
get
return false;
public bool Enabled
get
if(m_pHookHelper.FocusMap == null) return false;
return true;
public string HelpFile
get
// TODO: Add ZoomIn.HelpFile getter implementation
return null;
public string Category
get
return "Sample_Pan/Zoom";
#endregion
#region ITool Members
public void OnMouseDown(int button, int shift, int x, int y)
if(m_pHookHelper.ActiveView == null) return;
//If the active view is a page layout
if(m_pHookHelper.ActiveView is IPageLayout)
//Create a point in map coordinates
IPoint pPoint = (IPoint) m_pHookHelper.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y);
//Get the map if the point is within a data frame
IMap pMap = m_pHookHelper.ActiveView.HitTestMap(pPoint);
if(pMap == null) return;
//Set the map to be the page layout's focus map
if(pMap != m_pHookHelper.FocusMap)
m_pHookHelper.ActiveView.FocusMap = pMap;
m_pHookHelper.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
IActiveView pActiveView = (IActiveView) m_pHookHelper.FocusMap;
m_point = pActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y);
m_isMouseDown = true;
public void OnMouseMove(int button, int shift, int x, int y)
if(!m_isMouseDown) return;
//Get the focus map
//Start an envelope feedback
if(m_feedBack == null)
m_feedBack = new NewEnvelopeFeedbackClass();
m_feedBack.Display = pActiveView.ScreenDisplay;
m_feedBack.Start(m_point);
//Move the envelope feedback
m_feedBack.MoveTo(pActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y));
public void OnMouseUp(int button, int shift, int x, int y)
//Get the focus map
//If an envelope has not been tracked
IEnvelope pEnvelope;
//Zoom in from mouse click
pEnvelope = pActiveView.Extent;
pEnvelope.Expand(0.5, 0.5, true);
pEnvelope.CenterAt(m_point);
else
//Stop the envelope feedback
pEnvelope = m_feedBack.Stop();
//Exit if the envelope height or width is 0
if(pEnvelope.Width ==0 || pEnvelope.Height == 0)
m_feedBack = null;
m_isMouseDown = false;
//Set the new extent
pActiveView.Extent = pEnvelope;
//Refresh the active view
pActiveView.Refresh();
m_feedBack = null;
public void OnKeyDown(int keyCode, int shift)
if(m_isMouseDown)
if(keyCode == 27)
m_feedBack = null;
m_pHookHelper.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewForeground, null, null);
public void OnKeyUp(int keyCode, int shift)
// TODO: Add ZoomIn.OnKeyUp implementation
public int Cursor
get
if(m_isMouseDown)
return m_moveZoomInCur.Handle.ToInt32();
else
return m_zoomInCur.Handle.ToInt32();
public bool OnContextMenu(int x, int y)
// TODO: Add ZoomIn.OnContextMenu implementation
return false;
public bool Deactivate()
return true;
public void Refresh(int hdc)
// TODO: Add ZoomIn.Refresh implementation
public void OnDblClick()
// TODO: Add ZoomIn.OnDblClick implementation
#endregion
