# Create Geoprocessing Object import sys, os, arcgisscripting import arcpy from arcpy import env gp = arcgisscripting.create() #I DONT UNDERSTAND WHAT IS THE WILDCARD IN THIS EXAMPLE AND HOW CAN I CHANGE IT TO SO THAT IT CAN BE USED IN MY SCRIPT # Usage string usage = "<input_workspace> <projection> {data_type} {wildcard} {type} {overwrite_projection}" # Set some global variables... # Set wildcard for data filter. Default is * (all) wildcard = "*" # Set type for data filter. Default is ALL type = "ALL" # Set boolean for overwriting projection definition. Default is YES (true). bOverwriteProjection = True # Set boolean for branching into subdirectories. Default is NO (false). bRecursive = 0 def DefineProjection(inputWorkspace): gp.AddMessage("Searching for data in " + inputWorkspace) ##print inputWorkspace gp.workspace = inputWorkspace #Loop through each featureclass in input workspace and define a projection if data_type == "FEATURES": datasets = gp.listfeatureclasses(wildcard, type) dataset = datasets.Next() else: #data_type is RASTERS datasets = gp.listrasters(wildcard, type) dataset = datasets.Next() while dataset: # If {overwrite_projection} is NO, # check if the feature class has a projection already define by doing a describe. bDefineProject = 0 if bOverwriteProjection == 0: gp.AddMessage("Checking " + dataset) dsc = gp.Describe(dataset) if dsc.SpatialReference.Name == "Unknown": bDefineProject = 1 else: print "Projection already defined and will not be changed." gp.AddMessage("Projection already defined and will not be changed.") else: # {overwrite_projection} is "YES" bDefineProject = 1 if bDefineProject == 1: try: gp.AddMessage("Defining projection for " + inputWorkspace + "\\" + dataset) gp.defineprojection_management(dataset, prj) print "Successfully defined projection for " + inputWorkspace + "\\" + dataset except: # Print Error Messages print gp.getmessages(2) dataset = datasets.Next() if bRecursive == 1: if os.path.isdir(inputWorkspace): lstDir = os.listdir(inputWorkspace) for dir in lstDir: subDir = inputWorkspace + "\\" + dir if os.path.isdir(subDir): ##print "Branching into " + subDir DefineProjection(subDir) try: #Check if all required parameters have been provided. if len(sys.argv) < 3: raise Exception, "Invalid number of parameters provided. \n" + "Usage: " + usage # Set the input workspace environment inputWorkspace = ("C:\\Animals") #Check if <input_workspace> exists if not gp.exists(inputWorkspace): gp.AddError("Workspace " + inputWorkspace + " does not exist") raise Exception, "<input_workspace> does not exist." else: gp.AddMessage("Input workspace: " + inputWorkspace) # Set the projection information for multiple featureclasses. # First set the featureclasses to WGS84 and then Cylindrical Equal Area prj = r"C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj" prj = r"C:\Program Files (x86)\ArcGIS\Desktop10.0\"Coordinate Systems\Projected Coordinate Systems\World\Cylindrical Equal Area (world).prj" # Call the DefineProjection routine DefineProjection(inputWorkspace) except Exception, ErrDesc: gp.AddError(ErrDesc) print ErrDesc
