navtechie
Stuck on error: esri.layers.WMSLayerInfo is not a constructor
Discussion created by navtechie on Jan 6, 2012
Latest reply on Jun 8, 2016 by jabuhlong
Hi all,
Let me preface this with the knowledge that my skills in javascript are "enough to cause trouble" at best.
With that in mind, I have the html block below which has:
1: basemap of a custom tiled map layer using a service that is internal to our company.
2: I am trying to overlay a WMS,  non-tiled, layer on top of that.
I keep getting the error below and the WMS layer will not draw or connect. What am I missing or doing wrong?
I have removed some non-map related code so that this will fit in the code block.
Thanks in advance.
[Break On This Error] var layer1 = new esri.layers.WMSLay...itle:"PD_SPATIAL_CLUSTERED_POINT"});
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="layout" content="main" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript">
        var djConfig = {
            parseOnLoad: true
    </script>
 <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script>
        dojo.require("esri.map");
        dojo.require("esri.toolbars.draw");
        dojo.require("esri.layers.tiled")
        dojo.require("dijit.dijit");
        dojo.require("esri.layers.wmts")
        dojo.declare("com.nokia.QuadKeyLayer", esri.layers.TiledMapServiceLayer, {
            constructor: function (url) {
                this.cacheUrl = url;
                this.spatialReference = new esri.SpatialReference({
                    wkid: 3857
                this.tileInfo = new esri.layers.TileInfo({
                    rows: 256,
                    cols: 256,
                    dpi: 96,
                    format: "PNG8",
                    compressionQuality: 0,
                    origin: {
                        x: -20037508.342787,
                        y: 20037508.342787
                    spatialReference: {
                        wkid: 3857
                    lods: [{
                        level: 0,
                        scale: 591657527.591555,
                        resolution: 156543.033928
                        level: 1,
                        scale: 295828763.795777,
                        resolution: 78271.5169639999
                        level: 2,
                        scale: 147914381.897889,
                        resolution: 39135.7584820001
                        level: 3,
                        scale: 73957190.948944,
                        resolution: 19567.8792409999
                        level: 4,
                        scale: 36978595.474472,
                        resolution: 9783.93962049996
                        level: 5,
                        scale: 18489297.737236,
                        resolution: 4891.96981024998
                        level: 6,
                        scale: 9244648.868618,
                        resolution: 2445.98490512499
                        level: 7,
                        scale: 4622324.434309,
                        resolution: 1222.99245256249
                        level: 8,
                        scale: 2311162.217155,
                        resolution: 611.49622628138
                        level: 9,
                        scale: 1155581.108577,
                        resolution: 305.748113140558
                        level: 10,
                        scale: 577790.554289,
                        resolution: 152.874056570411
                        level: 11,
                        scale: 288895.277144,
                        resolution: 76.4370282850732
                        level: 12,
                        scale: 144447.638572,
                        resolution: 38.2185141425366
                        level: 13,
                        scale: 72223.819286,
                        resolution: 19.1092570712683
                        level: 14,
                        scale: 36111.909643,
                        resolution: 9.55462853563415
                        level: 15,
                        scale: 18055.954822,
                        resolution: 4.77731426794937
                        level: 16,
                        scale: 9027.977411,
                        resolution: 2.38865713397468
                        level: 17,
                        scale: 4513.988705,
                        resolution: 1.19432856685505
                        level: 18,
                        scale: 2256.994353,
                        resolution: 0.597164283559817
                this.fullExtent = new esri.geometry.Extent({
                    xmin: -20037508.34,
                    ymin: -20037508.34,
                    xmax: 20037508.34,
                    ymax: 20037508.34,
                    spatialReference: {
                        wkid: 3857
                this.initialExtent = new esri.geometry.Extent({
                    xmin: -20037508.34,
                    ymin: -20037508.34,
                    xmax: 20037508.34,
                    ymax: 20037508.34,
                    spatialReference: {
                        wkid: 3857
                this.serverIndex = 0;
                this.loaded = true;
                this.onLoad(this);
            getTileUrl: function(level, row, col) {
                var quad = "";
                var i = 0;
                for (i = level; i > 0; i--)
                    var mask = 1 << (i - 1);
                    var cell = 0;
                    if ((col & mask) != 0)
                        cell++;
                    if ((row & mask) != 0)
                        cell += 2;
                    quad += cell;
                return this.cacheUrl + quad;
        var map, osmLayer, editLayer, toolbar;
  function init() {
            var extent = new esri.geometry.Extent({"xmin":-10017753.324052965,"ymin":3508287.6149750105,
                "xmax":-10016081.264059184,"ymax":3509481.9435419976,"spatialReference":{"wkid":900913}});
            map = new esri.Map("map",{extent:extent,logo:false});
            osmLayer = new com.nokia.QuadKeyLayer("http://prd.lbsp.navteq.com/mgi/6.0/quadkey?token=JSLOCAPI_TEST_LBSP_ALL&quadkey=");
            map.addLayer(osmLayer);
   var layer1 = new esri.layers.WMSLayerInfo({name:"probe:PD_SPATIAL_CLUSTERED_POINT",title:"PD_SPATIAL_CLUSTERED_POINT"});
   var resourceInfo = {
   extent: new esri.geometry.Extent(-126.40869140625,31.025390625,-109.66552734375,41.5283203125,{wkid: 4326}),
   layerInfos: [layer1]
   var wmsLayer = new esri.layers.WMSLayer("http://pchiimpapp01.hq.navteq.com:8080/geoserver/wms?TILED=TRUE",
   {resourceInfo: resourceInfo,
   visibleLayers: ["probe:PD_SPATIAL_CLUSTERED_POINT"]}
   map.addLayers([wmsLayer]);
            createToolbar(map);
        function createToolbar(themap) {
            dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
            toolbar = new esri.toolbars.Draw(map);
            dojo.connect(toolbar, "onDrawEnd", addToMap);
        function addToMap(geometry) {
            toolbar.deactivate();
            map.showZoomSlider();
            var symbol = new esri.symbol.CartographicLineSymbol(esri.symbol.CartographicLineSymbol.STYLE_SOLID,
                    new dojo.Color([150,150,150]), 2, esri.symbol.CartographicLineSymbol.CAP_ROUND,
                    esri.symbol.CartographicLineSymbol.JOIN_MITER, 5);
            var graphic = new esri.Graphic(geometry, symbol);
            map.graphics.add(graphic);
            var t = esri.geometry.webMercatorToGeographic(geometry);
            var transformedGeo = esri.geometry.webMercatorToGeographic(geometry);
            var json = transformedGeo.paths.toJSON();
            new Ajax.Request('/fallout-ui/task/submitLink', { method:'post', contentType:'application/json', postBody: Object.toJSON({  geometry: transformedGeo.paths[0] }) });
        function startEdit() {
            map.graphics.clear();
            toolbar.activate(esri.toolbars.Draw.POLYLINE);
            map.hideZoomSlider();
        dojo.addOnLoad(init);
    </script>
</head>
<body class="claro" style="font-size: small; font-family: Arial Unicode MS,Arial,sans-serif;">
    <div id="map" style="position:relative;width:700px; height:500px; border:1px solid #000;">
    </div>
    <button onclick="startEdit()">Draw Link</button>
</body>
</html>
Outcomes
