# Import arcpy module import arcpy # Local variables: AUSTIN_WWManhole = "Database Connections\\wwwgisoraold.sde\\AUSTIN.AustinWastewater\\AUSTIN.WWManhole" IMSV7_COMPSMH = "Database Connections\\Hansen_Tables_Production.odc\\IMSV7.COMPSMH" # Join tables based on COMPKEY field, only keep matching records arcpy.AddJoin_management(AUSTIN_WWManhole, "COMPKEY", IMSV7_COMPSMH, "COMPKEY", "KEEP_COMMON") # Select records where METERED = 'Y' arcpy.SelectLayerByAttribute_management(AUSTIN_WWManhole, "NEW_SELECTION", "\"IMSV7.METERED\" = 'Y'") # Calculate METERINDICATOR = "Y" for selected records arcpy.CalculateField_management(AUSTIN_WWManhole, "AUSTIN.WWManhole.METERINDICATOR", "\"Y\"", "PYTHON_9.3", "") # Select records where METERED = 'N' and METERINDICATOR = 'Y' arcpy.SelectLayerByAttribute_management(AUSTIN_WWManhole, "NEW_SELECTION", "\"IMSV7.METERED\" = 'N' AND AUSTIN.WWManhole.METERINDICATOR = 'Y'") # Calculate METERINDICATOR = "N" for selected records arcpy.CalculateField_management(AUSTIN_WWManhole, "AUSTIN.WWManhole.METERINDICATOR", "\"N\"", "PYTHON_9.3", "") print "Complete"
I think what you have there will work, you just need to convert your feature classes to feature layers.
Use arcpy.MakeFeatureLayer(AUSTIN_WWMHOLE,"Manhole") for example, and then just use "Manhole" instead of your feature class for inputs in the other commands.
For your table you might have to use arcpy.MakeTableView to get the join to work as well.
EDIT: The joinfield mentioned above probably won't work because it permanently adds a field...I assume you wouldn't want that for an SDE feature class.
# Import arcpy module import arcpy # Local variables: AUSTIN_WWManhole = "Database Connections\\wwwgisoraold.sde\\AUSTIN.AustinWastewater\\AUSTIN.WWManhole" IMSV7_COMPSMH = "Database Connections\\Hansen_Tables_Production.odc\\IMSV7.COMPSMH" arcpy.MakeFeatureLayer(AUSTIN_WWManhole,"Manhole") arcpy.MakeTableView(IMSV7_COMPSMH,"Table") # Join tables based on COMPKEY field, only keep matching records arcpy.AddJoin_management("Manhole", "COMPKEY", "Table", "COMPKEY", "KEEP_COMMON") # Select records where METERED = 'Y' arcpy.SelectLayerByAttribute_management("Manhole", "NEW_SELECTION", "\"IMSV7.METERED\" = 'Y'") # Calculate METERINDICATOR = "Y" for selected records arcpy.CalculateField_management("Manhole", "AUSTIN.WWManhole.METERINDICATOR", "\"Y\"", "PYTHON_9.3", "") # Select records where METERED = 'N' and METERINDICATOR = 'Y' arcpy.SelectLayerByAttribute_management("Manhole", "NEW_SELECTION", "\"IMSV7.METERED\" = 'N' AND AUSTIN.WWManhole.METERINDICATOR = 'Y'") # Calculate METERINDICATOR = "N" for selected records arcpy.CalculateField_management("Manhole", "AUSTIN.WWManhole.METERINDICATOR", "\"N\"", "PYTHON_9.3", "") print "Complete"
# Import arcpy module import arcpy # Local variables: IMSV7_COMPSMH = "C:\\Users\\readj\\AppData\\Roaming\\ESRI\\Desktop10.0\\ArcCatalog\\Hansen_Tables_Production.odc\\IMSV7.COMPSMH" AUSTIN_WWManhole = "Database Connections\\wwwgisoraold.sde\\AUSTIN.AustinWastewater\\AUSTIN.WWManhole" WWManhole_View = "WWManhole_View" print " " print "Update Meter Indicator Script STARTED: " + str(datetime.datetime.now()) print " " # Make Table View of WWManhole arcpy.MakeTableView_management(AUSTIN_WWManhole, WWManhole_View) # Join tables based on COMPKEY field, only keep matching records arcpy.AddJoin_management(WWManhole_View, "COMPKEY", IMSV7_COMPSMH, "COMPKEY", "KEEP_COMMON") print "Tables Joined: " + str(datetime.datetime.now()) # Select records where METERED = 'Y' arcpy.SelectLayerByAttribute_management(WWManhole_View, "NEW_SELECTION", "METERED = 'Y'") # Calculate METERINDICATOR = "Y" for selected records arcpy.CalculateField_management(WWManhole_View, "AUSTIN.WWManhole.METERINDICATOR", "'Y'", "PYTHON") print "Calculated METERINDICATOR = 'Y': " + str(datetime.datetime.now()) # Select records where METERED = 'N' and METERINDICATOR = 'Y' arcpy.SelectLayerByAttribute_management(WWManhole_View, "NEW_SELECTION", "METERED = 'N' AND AUSTIN.WWManhole.METERINDICATOR = 'Y'") # Calculate METERINDICATOR = "N" for selected records arcpy.CalculateField_management(WWManhole_View, "AUSTIN.WWManhole.METERINDICATOR", "'N'", "PYTHON") print "Calculated METERINDICATOR = 'N': " + str(datetime.datetime.now()) print " " print "Update Meter Indicator Script COMPLETED: " + str(datetime.datetime.now())
