building from the example here:http://help.arcgis.com/en/webapi/javascript/arcgis/demos/find/find_map_datagrid.htmlI have a dropdown menu, to create a variable. My intention is to be able to search on more than one feature class/"find task"Here is the code from within <body> for the dropdown menu:
<div id="rightPane" dojotype="dijit.layout.ContentPane" region="right">
<form>
Search by :
<select id="myList" onchange="searchQual()">
<option></option>
<option>District</option>
<option>Division</option>
</select>
<p><input type="text" id="searchQualVal" size="0"></p>
</form>
Search Value: <input type="text" id="searchVal" size="10" value="1068"/>
<button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ doFindFunc();}, value:"Search"'>
Search
</button>
and im trying to use the values "searchQual" and "searchQualVal" to here:
function doFindFunc() {
//Set the search text to the value in the box
findParams.searchText = dojo.byId("searchVal").value;
//it never gets into this switch
switch (searchQualVal){
case "District":
findDistrict.execute(findParams,showResults);
break;
case "Division":
findDivision.execute(findParams,showResults);
break;
please help!Thank you.
