cquirion
esriaddinx file and class full names
Discussion created by cquirion on Dec 21, 2011
Latest reply on Dec 21, 2011 by richwawr
I am developping 3 toolbars with multiple buttons and decided to have my buttons in different namespaces. I looked up the <AddIn>'s namespace parameter and the <Button>'s class documentation , before changing anything.
The <Button>'s class documentation states :
"If this class is not in the default library namespace specified on the root AddIn element, the class name must be the full name (namespace.className)"
However, if i enter any values with ".", the ArcGISAddInHostGenerator generates invalid Config.Designer.cs entries...
For exemple :
       internal class IDs {
            /// <summary>
            /// Returns 'TestNamespace_cmdTest', the id declared for Add-in Button class 'TestNamespace.cmdTest'
            /// </summary>
            internal static string TestNamespace.cmdTest {
                get {
                    return "TestNamespace_cmdTest";
This yields the two following errors :
Error 1 The modifier 'static' is not valid for this item
Error 2 The modifier 'internal' is not valid for this item
Of course, i could go back to "everything in the same namespace" but id rather not, especially if this is documented as a supported feature...
Anything im doing wrong or is this a bug/wasn't tested ?
Thanks in advance
Edit, for reference, this would be the button entry in the Config.esriaddinx
    <Button id="TestNamespace_cmdTest"
      class="TestNamespace.cmdTest"
      message="Test"
      caption="Test"
      tip="Test"
      category="Test"
      image="Images\Test-64x64.png"
      onDemand="false"/>
Outcomes
