Hello, I have an Education Edition of ArcGIS10. Can I use 'Spatial Analyst' tools in it? If yes, how should I enable it? Same is the case with 3D Analyst toolbar.
I am not sure if those extensions are included; however, you can try a few things. Open the ArcGIS Administrator and check to see that the tools are authorized. (Be sure to close ArcMap or it will not open.) You can also go into ArcMap > Customize > Extensions and see if the extension is there. If it is, then it has been installed, and if not then you will need to install the additional feature. Check the box to activate the extension. Why are my Spatial Analyst and 3D Analyst toolbars gray? Adding additional installation features
