function init() { //set position of slider at 10 pixels offset from right/top of map //set slider height to 100 pixels esri.config.defaults.map.slider = { right:"10px", top:"10px", width:null, height:"300px" };
.claro .dijitSliderDecrementIconH, .claro .dijitSliderIncrementIconH, .claro .dijitSliderDecrementIconV, .claro .dijitSliderIncrementIconV { background: url("../images/arrows.png") no-repeat top left; border: 1px solid #B5BCC7; border-radius: 2px 2px 2px 2px; font-size: 1px; } .claro .dijitSliderDecrementIconV { background-position: 0 0; width:16px; height:16px; border: none; } .claro .dijitSliderIncrementIconV { background-position: 0 -66px; width:16px; height:16px; border:none; }
To modify the size, location and labels for the zoom slider you can use the options in esri.config. Here's an example that modifies the location and size:function init() { //set position of slider at 10 pixels offset from right/top of map //set slider height to 100 pixels esri.config.defaults.map.slider = { right:"10px", top:"10px", width:null, height:"300px" };
For the arrows here's some css that changes the arrow image. In this case I have a sprite that contains two arrows (up and down). The positions specified for the up and down arrow using background-position specify the location of the individual image within the sprite. If you use a tool like this one to generate the sprite it will provide you with the location coords for each of the contained images.
http://spritegen.website-performance.org/.claro .dijitSliderDecrementIconH, .claro .dijitSliderIncrementIconH, .claro .dijitSliderDecrementIconV, .claro .dijitSliderIncrementIconV { background: url("../images/arrows.png") no-repeat top left; border: 1px solid #B5BCC7; border-radius: 2px 2px 2px 2px; font-size: 1px; } .claro .dijitSliderDecrementIconV { background-position: 0 0; width:16px; height:16px; border: none; } .claro .dijitSliderIncrementIconV { background-position: 0 -66px; width:16px; height:16px; border:none; }
Cant we change icon of navigation tools
Veena,
Actually those are text and not icons:
<div id="map_zoom_slider" class="esriSimpleSlider esriSimpleSliderVertical esriSimpleSliderTL" style="z-index: 30;"> <div class="esriSimpleSliderIncrementButton" title="Zoom In"> <span>+</span> </div> <div class="esriSimpleSliderDecrementButton" title="Zoom Out"> <span>–</span> </div> </div>
So you would have to manipulate the dom and replace the span elements with an image. I have never had a desire to do this so I don't have a code sample for that.
Here's an example showing the approach Robert Scheitlin mentioned. This code uses dojo/query to find the span then adds an img. See the attached zip for a full working example.
query(".esriSimpleSliderIncrementButton span")[0].innerHTML = "<img src='plus.png' class='slider-icons'/>" query(".esriSimpleSliderDecrementButton span")[0].innerHTML = "<img src='minus.png' class='slider-icons' />"
