Greetings,
I see it's possible to export what ESRI calls "cross-validation" results from a kriging interpolation using the "Save cross-validation..." button in the Geostatistical Wizard. However, this button disappears in the validation step (that is, if you chose new data on which to test your "trained" model). I would very much like to export the validation results (NOT the "cross-validation" results). Is this possible? I'm using Indicator Kriging with 9.3.
Thank you for any help!
Zach
