jbenson
Widget: BasemapGallery dropdown question
Discussion created by jbenson on Dec 20, 2011
Latest reply on May 15, 2013 by VPrasad-esristaff
I just posted this, but can't find it so I will try again.
I am trying to duplicate the widget BasemapGallery- dropdown (http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm) button.  I want this particular one because I can customize the dropdown window and I want a simple dropdown button.  The example uses all Bing items.  I want to use the basemaps Ocean_Basemap, NatGeo_World_Map, and I3_Imagery_Prime_World_2D .  My confusion is in the type and id.  The example code shows the following:
      function createBasemapGallery(){
        //Manually create a list of basemaps to display
        var basemaps = [];
        var basemapRoad = new esri.dijit.Basemap({
          layers: [new esri.dijit.BasemapLayer({
            type: "BingMapsRoad"
          title: "Road"
        basemaps.push(basemapRoad);
        var basemapAerial = new esri.dijit.Basemap({
            type: "BingMapsAerial"
          title: "Aerial"
        basemaps.push(basemapAerial);
        var basemapHybrid = new esri.dijit.Basemap({
            type: "BingMapsHybrid"
          title: "Aerial with labels"
        basemaps.push(basemapHybrid);
        basemapGallery = new esri.dijit.BasemapGallery({
          showArcGISBasemaps: false,
          basemaps: basemaps,
          bingMapsKey: bingKey,
          map: map
Do I replace type: �??BingMapsAerial�?� with �??Ocean_Basemap�?�?  What do I use instead for id: �??bmRoad�?�?  I do not understand where type and id are coming from.  When I look at http://services.arcgisonline.com/ArcGIS/rest/services/ and go into the individual layers, I still can�??t seem to find similar items.  I realize the basemaps are already there, but it looks like I still have to define them to build the custom menu.  If there is a simpler way, I�??m game, but I am a beginner.
Thanks for your help!
Outcomes
