i'm the first time use the findtask ,and i've a question about that :the code in flex :
private function myResultFunction(event:FindEvent):void{
for(var i:Number=0;i<event.findResults.length;i++)
var result:FindResult=event.findResults as FindResult;
var graphic:Graphic=result.feature;
for(var key:String in graphic.attributes)
trace(key);
trace(graphic.attributes[key]); // if the value is null in database, this consloe "Null"
trace(graphic.attributes[key] is String) // but this console "true"
trace(graphic.attributes[key]==null); // and this console "false"
i saw that all value in attributes is in string-type ,also the objects saved in database in date-type or null .and the result t is not the same with querytask.
so hao can i get the same type i have saved in database in findtask ?
thanks for your help !
