jwsury12
Creating a trend plane from a raster layer
Discussion created by jwsury12 on Dec 14, 2011
Is there any way to use a RasterLayer as the input to the IInterpolationOp.Trend function.  I can access my RasterLayer through the IGeoDataset Interface however the Trend function doesn't seem to like what it gets and throws an "ERROR 010085: SPOT is an invalid field name".  All of the help material suggests that the function expects a FeatureClass or a FeatureClassDescriptor.
I have added my attempts below.  The first works and generates a trend plane from LiDAR XY points.  The points are very cumbersome to work with and I was hoping in the second attempt (which doesn't work) to use the interpolated raster as my input elevations.
Your wise insights would be appreciated!
Public Sub CreateTrendPlane()
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pLiDARPointsLayer  As IFeatureLayer
Dim lSlopeFieldIndex As Long
Dim iCount As Integer
Dim iNumber As Integer
Dim pDALayer As IFeatureLayer
Dim pDAFeatCur As IFeatureCursor
Dim pDAFeat As IFeature
Dim pSF As ISpatialFilter
Dim pSelectionSet As ISelectionSet
Dim pOutputRaster As IRaster
Dim pSurfaceOp As ISurfaceOp
Dim pSlopeRaster As IRaster
Dim pArea As IArea
Dim pPoint As IPoint
Dim pRasterLayer As IRasterLayer
Dim pIdentify As IIdentify
Dim pArray As IArray
Dim pRasterIdentify As IRasterIdentifyObj
Const ElevationFieldName = "GRID_CODE"
Set pMxDoc = ThisDocument
Set pMap = pMxDoc.FocusMap
Set pDALayer = pMap.Layer(0) ' put DA layer at top of TOC
Set pLiDARPointsLayer = pMap.Layer(1) ' put LidarPoints layer next
lSlopeFieldIndex = pDALayer.FeatureClass.FindField("MySlope")
iCount = 1
iNumber = pDALayer.FeatureClass.FeatureCount(Nothing)
Set pDAFeatCur = pDALayer.FeatureClass.Search(Nothing, False)
Set pDAFeat = pDAFeatCur.NextFeature
While Not pDAFeat Is Nothing
    Set pSF = New SpatialFilter
    Set pSF.geometry = pDAFeat.Shape
    pSF.GeometryField = pLiDARPointsLayer.FeatureClass.ShapeFieldName
    pSF.SpatialRel = esriSpatialRelContains
    Set pSelectionSet = pLiDARPointsLayer.FeatureClass.Select(pSF, esriSelectionTypeIDSet, esriSelectionOptionNormal, Nothing)
    Dim pFDescr As IFeatureClassDescriptor
    Set pFDescr = New FeatureClassDescriptor
    pFDescr.CreateFromSelectionSet pSelectionSet, Nothing, ElevationFieldName
    Dim pInterpolationOp As IInterpolationOp
    Set pInterpolationOp = New RasterInterpolationOp
    Dim pRasterAnalysisEnv As IRasterAnalysisEnvironment
    Set pRasterAnalysisEnv = pInterpolationOp
    pRasterAnalysisEnv.SetCellSize esriRasterEnvValue, CVar(15)
    pRasterAnalysisEnv.SetExtent esriRasterEnvMaxOf
    Dim pInputPoints As IGeoDataset
    Set pInputPoints = pFDescr
    Set pOutputRaster = pInterpolationOp.Trend(pInputPoints, esriGeoAnalysisLinearTrend, 1)
    Set pSurfaceOp = New RasterSurfaceOp
    Set pSlopeRaster = pSurfaceOp.Slope(pOutputRaster, esriGeoAnalysisSlopePercentrise)
    Set pArea = pDAFeat.Shape
    Set pPoint = pArea.Centroid
    Set pRasterLayer = New rasterLayer
    pRasterLayer.CreateFromRaster pSlopeRaster
    Set pIdentify = pRasterLayer
    Set pArray = pIdentify.Identify(pPoint)
    Set pRasterIdentify = pArray.Element(0)
    pDAFeat.Value(lSlopeFieldIndex) = pRasterIdentify.Name
    pDAFeat.Store
    ThisDocument.Parent.StatusBar.Message(0) = "Calculated " & CStr(iCount) & " of " & CStr(iNumber)
    iCount = iCount + 1
Wend
MsgBox "Done"
End Sub
Public Sub CreateTrendPlaneUsingLiDAR()
        Dim pMap As IMap
        Dim pLiDARLayer As IRasterLayer
        Dim pRasterGDS As IGeoDataset
        Dim lAspectFieldIndex As Long
        Dim pAspectRaster As IRaster
        Dim pArea As IArea
        Set pLiDARLayer = pMap.Layer(1) ' put Lidar layer next
        Set pRasterGDS = pLiDARLayer
        lAspectFieldIndex = pDALayer.FeatureClass.FindField("MyAspect")
        iCount = 1
            pRasterAnalysisEnv.SetCellSize esriRasterEnvValue, 15
            pRasterAnalysisEnv.SetExtent esriRasterEnvValue, pDAFeat.Shape.Envelope
            Set pOutputRaster = pInterpolationOp.Trend(pRasterGDS, esriGeoAnalysisLinearTrend, 1)
            Set pAspectRaster = pSurfaceOp.Aspect(pOutputRaster)
            pDAFeat.Value(lAspectFieldIndex) = IdentifyPixelValue(pAspectRaster, pPoint.X, pPoint.Y)
            pDAFeat.Store
            pDAFeat.Value(lSlopeFieldIndex) = IdentifyPixelValue(pSlopeRaster, pPoint.X, pPoint.Y)
            pDAFeat.Store
            iCount = iCount + 1
        Wend
        MsgBox ("Done")
    End Sub
Outcomes
