java.lang.IllegalArgumentException: No configs match configSpec
552
12-14-2011 12:30 PM
TomaszCiesielski
Hi!
I have a problem during running sample application (file->new project->ArcGIS samples for android). Uncatch exception is thrown after application started and view is initialized with com.esri.android.map.MapView component inside. I see in logs that  java.lang.IllegalArgumentException: ("No configs match configSpec") is thrown. I use emulator to test my application with Android 2.2 or 2.3. Tell me what is wrong, please.
--9
I have same problem and the answer is...
"this version of SDK do not support for emulator."
I deploy sample project to android phone and it works fine.
Reference:
http://help.arcgis.com/en/arcgismobile/10.0/apis/android/help/#/What_s_new_in_version_1_0_1/01190000...
WillCrick
Please post SDK specific questions on the Android SDK forum here: http://forums.arcgis.com/forums/139-ArcGIS-Runtime-SDK-for-Android
This forum is for the ArcGIS for Android application.
cheers
Will
SwatiGadey
I have the same issue, if any solution to make it work on emulator please post here. It has been tough to troubleshoot the app when debugging it on phone.
Thanks.
varunanand
Im trying to follow the HelloMap tutorial given on the ESRI site for Android. I noticed that the HelloMap application will not run on the emulator so i tried running it on an android device 2.2.1 instead, but still it shows the same exception. Am i missing something?
Does the device need an active connection to the internet when testing such an application?
Varun
