Zoom to graphic
4485
12-13-2011 06:26 AM
MikeOnzay
Occasional Contributor III
I still don't understand how to zoom to the extent of a feature(graphic). The help/samples are not quite basic enough. I can see my graphic but I cannot zoom to it. I also want to use expand.
function showResults(featureSet){
 map.graphics.clear();
        var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID).setColor(new dojo.Color([255, 0, 0, 0.5]));
        //Loop through features in the featureSet and add them to the map.
        for (var i=0, il=featureSet.features.length; i<il; i++) {
 //Get the current feature from the featureSet.
        //Feature is a graphic
            var graphic = featureSet.features;
            graphic.setSymbol(symbol);
     graphic.geometry.getExtent().expand(0.5); //my attempt
            //Add graphic to the map graphics layer.
            map.graphics.add(graphic);
derekswingley1
If you want to get the extent for all of your features, there are a couple of options:
-use esri.graphicsExtent()
-build an extent using esri.geometry.Extent.union() to manually build an extent from your features
Once you have an extent, pass it to map.setExtent() to zoom to your features.
MikeOnzay
Got it. Finally. Thanks.
