greenlaw
ArcGIS Engine 10.1 Beta 2
Discussion created by greenlaw on Dec 12, 2011
Latest reply on Dec 13, 2011 by greenlaw
Couldn't find any ArcGIS Engine forums, so hopefully this is the best place for this question.
I'm trying to get some ArcObjects 9.x Java code running on a new installation of ArcGIS Engine Runtime 10.1 Beta 2 for Linux, but keep encountering the following exception very early in the program execution:
AutomationException: 0x80040154 - Class not registered
        at com.esri.arcgis.interop.NativeObjRef.initNative(Native Method)
        at com.esri.arcgis.interop.NativeObjRef.a(Unknown Source)
        at com.esri.arcgis.interop.NativeObjRef.<init>(Unknown Source)
        at com.esri.arcgis.interop.Dispatch.createDispatch(Unknown Source)
        at com.esri.arcgis.interop.Dispatch.<init>(Unknown Source)
        at com.esri.arcgis.geodatabase.IWorkspaceFactoryProxy.<init>(Unknown Source)
        at com.esri.arcgis.datasourcesfile.ShapefileWorkspaceFactory.<init>(Unknown Source)
Compiling works fine.  My ArcGIS Engine install has been fully authorized.  I have added $ENGINEINSTALLDIR/bin to my PATH, and have run the proper init_java.sh script prior to execution (LD_LIBRARY_PATH looks fine).  My DISPLAY variable is also set correctly.  The newest arcobjects.jar file is on my classpath.
My program is able to get past the ArcGIS Engine initialization code:
EngineInitializer.initializeEngine();
AoInitialize aoInit = new AoInitialize();
aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeEngine);
...but as soon as I try to initialize an SdeWorkspaceFactory or ShapefileWorkspaceFactory, like this:
IWorkspaceFactory sdeWSF = new SdeWorkspaceFactory();
I get the same AutomationException.
Any help would be very much appreciated.
Jason
Outcomes
