When setting an ouputcoordinate system in python I keep getting an error.
Here's a sample of the code up to the point where the error occurs.
import arcpy, os, sys
print "Processing ..."
#set up a relative path. This returns the folder where the script is
relativePath = os.path.dirname(sys.argv[0])
#Set up environment settings
arcpy.env.workspace = "c:/.gdb"
arcpy.env.outputCoordinateSystem="Coordinate Systems/Projected Coordinate Systems/State Plane/NAD 1983(US Feet)/NAD 1983 StatePlane Pennsylvania North FIPS 3701(US Feet).prj"
This error is returned:
File "Y:\Planning\GIS Planning Analyst\projects\county_map_book\1_GenerateIndexLayers.py", line 11, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 505, in set_
self[env] = val
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 557, in __setitem__
ret_ = setattr(self._gp, item, value)
RuntimeError: <unprintable RuntimeError object>
Any help will be greatly appreciated.
SE
